Changed rear inner tube, now pedals click as I pedal
I found a really good video, but I don't have the strength to hold my bike in one hand and drop the wheel out with the other!
Good grief, that's one heavy bike !
Another thought - some mtb rear mech's have a clutch lever that has to be disengaged in order to get the wheel in and out. A small lever on the body of the rear mech.
fairyhedgehog
fairyhedgehog
You've got a relationship with a bike shop, the one you had it serviced in. Take the bike in there, say "it keeps making a clicky noise since I changed the tube, can you tell me what I did wrong?". I'd be very surprised (assuming they aren't busy when you go in) if they don't give you a quick lesson in removing and replacing the rear wheel.
Good plan. Thank you!
I always flip my bike over, I'd never get the wheel back that way.
That's a relief! I thought it was just me!
fairyhedgehog
fairyhedgehog
If I recall, you got the bike from Pearsons, the workshop lads are very helpful, as above, I'm sure they'd take a look and give you a hand. If too far, Fudges would do so too.
I'm certainly no mechanic as @jefmcg will attest, but I'm working in Epsom today and happy to have a look at lunchtime (office behind Odeon)...if Fudges can't help (which I'm sure they will :smile: )
That's really kind! It seems to be OK at the moment. I'm wondering if it's when I'm not pedalling fast enough, and there's a bit of slack. I was in Fudges today to get new tyres - so I don't keep getting punctures! - but I forgot about the clicking.
I did check everything everyone had suggested and there was nothing obvious. If it continues, I'll pop back and see if Fudges can help.
fairyhedgehog
fairyhedgehog
Is it a click for each pedal rotation? If it's a click per wheel rotation it might be the magnet swiping the body of your computer pick-up (assuming you have one).
It varies - one or two clicks per rotation. I use my phone and ViewRanger for speed and distance etc. so I don't have a pickup.
Glasgow
Try holding it from the rear rack if you have one, then slide the wheel under.
I use a stand at home, on the road I put the back on the side, the non drive one or you'll risk bashing the derailleur.
What ever way you use, stand the bike and give the wheel a good pull to sit it in the dropouts before you tighten the quick release.
