Sorry, I hadn't twigged that it was new.
Now it looks like you were right after all, it's not a new derailleur
![Laugh :laugh: :laugh:](/styles/default/xenforo/smls/laugh.gif)
Cheers guys. Yea it was late. Going to have another go when I get in from work.
On the actual shifter not moving into 3rd gear (even when not clamped into derailleur) any advice
These are the shifters I bought
http://www.ebay.co.uk/itm/221050498913
Also sorry if I didn't say, but the derailleur isn't a replacement. It's what came with the bike when it was bought. But the bike was never able to get into 3rd gear
1. You are cross chaining. The combination of big/big and small/small cogs is not a good idea as the further you go, the more extreme the angle of the chain running front to back. Try to remember that the H and L screws only limit how far the derailleur can travel. The basically just stop the chain from falling off the edge. Adjust to get the best chain line with minimum of rubbing. If it rubs, it's time to change up/down chainrings.Ok new shifter arrived yesterday and Last night I got it wired up. I'm hitting all the gears.... BUT....still have some issues.
Any suggestions? I can post some photo or video if it helps?
- When the front gear is on the large gear and the back gear is on the large gear the chain rubs badly up the inside of the derailleur. I've adjusted the H and L screws for a few hours and what I have at the min is the best as it gets into all 3 gears. Any slight adjustment in either and it can't hit all gears.
- When in I go up the front gears it goes from 1st to 2nd. But to go fully into 2nd you have to pull it slightly past 2nd. Sometimes into 3rd. Then when in 2nd u can push the shifter back into 2nd avid the gear will sit allowing you to push again into 3rd with no problem. Working but not ideal.
- More of concern is that when you are in 3rd the largest gear on the front and start to go down it jumps from 3rd all the way to 1st. I know it's not the shifter as when loose it goes up and down as normal. I'm more concerned with that as when cycling such a quick drop in tension into a low gear with my legs going quickly then peddling air could be very sore after a long cycle.
