To be fair, you were the one that mentioned 'high pressure', not me. So it's a bit rich you accusing me of playing semantics for picking you up on something which you won't clarify. Anyway, what on earth have hypoid gear oils got to do with bicycle chain lube? And what is your definition of 'good' oil?
Allow me to suggest an alternative test:
1) lube a chain regularly with WD40
2) see how you get on
I suspect two things
a) you won't bother to do the experiment
b) you'll respond by patronising me again with something irrelevant about oil science
To be clear though, I'm not necessarily recommending WD as a chain lube (I don't use it myself) - I'm just saying it will do, as long as it is used regularly. It provides a very thin coating of oil on the chain, which is pretty much all you can ask of any chain lube. How long it stays there is another issue, which brings me back to my original point.
