Hi all,
I ride a Ridgeback Horizon tourer - so effectively a road bike - with 8 speed read casette and Shimano gears. I recently had problems with my chain slipping slightly at the back. After investigation I realised that it was because one of the links in my chain had frozen. This made sense as the slipping was at regular intervals, very brief and only when I put higher tension on the chain.
I replaced my chain last night and very pleased with myself set off this morning. The problem has changed and got much worse. Now when I put anything other than the lightest pressure on the pedals the chain slips but but a large amount, i.e. it seems to only stop when my crank has reached the lowest point (this is different to before when the slip was very brief and clearly linked to the defective chain link). The chain isn't slipping on the cassette, just the derailleur, specifically the lower two small cogs (from what I can tell).
I have guesses at what the problem is but wanted to check before I shell out more cash. Firstly is it possible that I've put the wrong type of chain on the bike? The chain was "Oxford Standard" and looked identical to my last. Also I made sure I had the same chain length (in links) as before. Are there chain types that don't work well on road bikes?
My main suspicion is that the lower of the two small derailleur cogs is worn. Looking at the teeth they seem to be noticably shorter than the ones on the other cog. It wouldn't surprise me that under high tension the chain would just slip over these. Is this likely? My natural reaction is to think it's this, but I'm just surprised that this wasn't happening before (maybe my old chain was so gunked up that it just didn't slip?!). It's possible I've knackered the cog by cycling with the knackered chain. I ran the bike for about a week and a half with the minor slipping. Are the cogs this easy to damage.
Oh, and can the small cog be replaced (looks like it)?
Any insight would be appreciated before I go buying a whole new gear set
Cheers,
Andrew
Cheers,
Andrew
