Holdsworth
- Crewe, Cheshire
Well after getting my chainset replaced I am finding that when in the high gears on the cassette (6 and 7) and in the big ring, the chain is rubbing on the front derailleur. I have made sure that the derailleur is straight, I have adjusted the cable tension so that is just taught at the loosest setting, the limit screw for the top end is undone by a fair way.
This is a pain because the new chainset has two less teeth on it (LBS had nothing else in) so I need to use the higher gears at the back more often.
All that and it still rubs on the right-hand side of the 'railleur, it just can't move far enough out before the cable goes tight and won't move any more.
Any help is mucho appreciated
