NormanD
Lunatic Asylum Escapee
- Heworth the other side of life!
Erm, I've just looked up what cross-chaining is and, yeah I was cross-chaining. Ah well, you live and learn!
Could have saved yourself £35 for knowing that
Could have saved yourself £35 for knowing that![]()
I could indeed! Mind, it probably needed a service after I'd been fiddling with it. Ah well, it'll be good to see what the bike's like after a fettle from the experts. The brakes were a bit spongy on my debut ride. It's a big learning experience this cycling lark.
If you have 3 cogs on the front use the largert two rear cogs when in the smallest front cog. The fulk range in the middle and the the smallest two when in the largest front cog. For a double at the front treat the inside cog as the middle and use the smallest 3 os 4 in the outerHow many gears is normal to avoid to prevent cross chaining. I've got 16 on my road bike and I reckon I'm getting chain rub in about 6 of the gears. I'm also getting it in my lowest gear, which I can't avoid using when I'm slogging up hills.
Cheers![]()
Rub on both extremes of the gear range sounds like the limit screws need a minute adjustment.Hi
It's a double at the front. When I'm in the smaller of the front cogs I'm getting rub when I'm on the top two and bottom one of the rear cassette.
I've ridden MTBs before and never really experienced any issues with chain rub. When I first got the road bike I kept taking it back to the shop thinking the cables had stretched. Then i started looking at forums etc and discovered cross chaining and started to manage my gear selection a bit better. Having said that, I still get the sense I'm avoiding more gears than is 'normal' and wondered if the FD might need to be angled slightly different.
I so need to go on a bike maintenance course! I see Sky are doing some all day numbers or £125, but not sure if they are much cop
Cheers
Pleasure and best of luck.Thanks both. I stumbled across the half nudge by accident and that has helped to an extent. I'll take a closer look at the FD and give the limit screw(s) a 1/8 turn or so and see if that makes a difference.
Cheers![]()
Great newsGot the bike back today. The gears are now sorted, plus the brakes work properly. £35 well spent!
Great news![]()
