There are 2 screws on the mechanism facing you 1 is the low gear limit adjustment and the other the high gear limit adjustment. On my bike the lower one was the low gear. Put the dear in the lowest gear (large cog at the back and small cog at the front) and then turn the screw so the FD arm is just clear of the chain
Then put in high gear (smallest rear and largest front and do the same thing)
Then put it back in the lowest gear and make sure the shifter is that lowest position.. then Pull the cable so there is no slack.
If this does not work then you may have to adjust the height and angle of the deraileur and the repeat the steps above
I just I just took off my front deraileur for the first time as the pedal arm was touching it when in the highest gear
Gave it a good clean ... then took me ages to get it back on but now works a treat. I also feel great having done it!
These instructions helped
FD Instructions
