Dogtrousers
Lefty tighty. Get it righty.
Damn. I got CASTROL by mistake. That explains a lot.That's CASTOR oil you should be taking.
When I rode a chain-driven motorbike I used to take off the chain and boil it in a big round tin of black wax, which penetrated the links and resisted being flung off. Anything lighter would end up spattered all over the rear of the bike. Shaft drive was a fantastic little bit of technology, especially on a commuter.
Red diesel = a lot cheaper!!Diesel £1.20 a litre.
Hypoid Gear oil. Very cheap, quite sticky compared to oils, very well suited to maintaining oil film strength under pressure.
Only downside is it smells foul.
It isn't difficult, but different. Motorcycle chains and bicycle chains cannot be compared. The former is a bushing chain with O-rings on each and every pivot which keeps grease-for-life inside and uncontaminated. Any lubrication applied to the outside merely lubricates the O-rings.Dry ceramic lube on my motorbikes for years too. Same on road bikes too. All lovely and clean.
What's so difficult?
So what you're saying is, the Castrol Chain Wax, specifically designed for motorbike chains, works perfectly, but that Muc-Off Ceramic Lube, specifically designed for bicycle chains, does not!?!It isn't difficult, but different. Motorcycle chains and bicycle chains cannot be compared. The former is a bushing chain with O-rings on each and every pivot which keeps grease-for-life inside and uncontaminated. Any lubrication applied to the outside merely lubricates the O-rings.
Bicycle chains on the other hand are bushingless and sans O-rings. This means we have to use a lubricant that can flow inside upon application. The two applications are vastly different and comparisons are invalid.
No.So what you're saying is, the Castrol Chain Wax, specifically designed for motorbike chains, works perfectly, but that Muc-Off Ceramic Lube, specifically designed for bicycle chains, does not!?!
Edit: but that I should be using Chainsaw Oil or Diesel, designed specifically for...
Then I don't get your point?
If I interpret what you said correctly was that you use something called Dry Ceramic lubrication on motorcycle chains and on your bicycle chain too.Then I don't get your point?
Mine was that using the product designed for the job is usually the best way. Your reply suggests you disagree, but then you disagree with that too. ?
Hmmm, a water based lubricant, interesting. I might try that myself. <Googly Google...> This stuff i take it: http://www.scottoiler.com/uk/Cycle/Scottoiler-Ultimate-Bike-Solution-750ml/flypage.tpl.htmlIt's not so much the cost that I object to but the muck and grit that accumulates on the chain and transmission as that creates a grinding paste which causes wear.
I'm now trying a water-based lube sold by "Scot-oiler", the people that make oiler kits for motor bikes. Tried it for the first time on a really mucky day following salt being sprayed on the roads and returned with the bottom half of the bike covered with muck....all except the transmission which was a clean as when I left. I imagine that being water-based this would mean more applications would be needed.
No connection and all that.....
What I initially said was that I used a Dry Ceramic product on both types of chain. It was your assumption that this was a single product applied to both. I never said that was the case and, when my motorbike got written off recently, I gave all of my motorbike chain stuff to mate. Was never tempted to use on either of my bicycles.If I interpret what you said correctly was that you use something called Dry Ceramic lubrication on motorcycle chains and on your bicycle chain too.
My point is that a product designed for a motorcycle chain with internal lubrication sealed in with O-rings is not ideal for bicycles. I also make the further point that wax products or anything that isn't liquid oil is also not ideal for bicycle chains because bicycle chains are a bushingless design that requires a flow lubricant.
I'll make a third point, which is any oil used on a bicycle chain that does not turn black with use is also not suitable.
A bicycle chain, or motorbike chain for that matter, undergoes two different work cycles; the tension cycle and the return run. On a bicycle the tension cycle is the part on top, from where the chain departs the rear sprocket to where it enters the front sprocket. Any link in this cycle experiences only tension. As soon as the link goes around the front chainring it starts to relax and enters the return run where it remains in relative slack until it turns the corner around the top of the cassette again.
During the tension cycle oil between the bushing and pin is squeezed out of the interface and on the return run oil returns again. Oil thus flows in and out. The inflow is by way of capillary action and the outflow is because the capillary is squeezed and the fluid moves elsewhere. The black you so quickly see on the chain is steel particles ground off inside the chain when it articulates under tension. The reason the black oil can eventually be seen is evidence that the oil flows as you pedal.
Should you apply wax to the chain then the tension cycle squeezes the wax out but it cannot flow back in. We see evidence of this in the wax that settles on the pulleys and outside of the chain sideplates. The wax wasn't applied there, it moved there. However, it cannot move back. The chain doesn't turn black, which means that the grit remains inside and also that the insides are running without the aid of lubricant.
On motorcycle chains the inside is greased for life. Wax is sprayed on the outside to dampen the noise from sprocket on chain and also to lubricate the outside of the chain a bit. Oil can't be used here because of the speed the chain moves and it will shoot off within a few kilometers. A second reason oil is not used here is because these are bushing chains that are just about impossible to clean and once dirt is inside it remains inside and reduces chain life.
Bicycle chains are open and liquids can freely flow in and out. It is easy to wash a chain and completely clean out the insides and replace with fresh oil and this should be done frequently if you care about chain life.
As I explained earlier on, a suitable chain lubricant is oil that's neither too thick or too thin and it is easy to find the sweet spot.
