[QUOTE 4636995, member: 9609"]if the chain has had a good soaking on wet salty roads the simplest and most thorough solution is to boil it in oil (I use chainsaw as its sticky and I also have loads of it) . It leaves the chain beautifully clean and you get virtually no wear on your next ride. Surprisingly quick to do, drop it in a tin heat it up to 100c, lift out and allow to drip dry, by the time you have rubbed the rest of the bike down it is ready to refit. Lift it out when hot though, I have tried letting it cool in the oil but the problem here is the inner parts of the rollers stay full of oil and when you start pedalling it all ouses out and makes a bit of a mess.[/QUOTE]
I've mentioned this before in another thread - but if the oil is already in a liquid state, then boiling it will not add anything useful to the lubrication process.
