swee'pea99
People clean chains?
Don't use a thong, they get stuck in the front mech....apparently.
GOAB
I used to use people but the Vicar was quite vocal about being left covered in grime, so I use rags now.People clean chains?
WowStop messing about with dirty rags and do the job properly as described by the expert in this link:
http://www.sheldonbrown.com/chainclean.html
After every ride too.Stop messing about with dirty rags and do the job properly as described by the expert in this link:
That's what they say, but I don't believe them.You are a bad person.
but what about all the grit and muck that builds up between the links?Don't degrease it. Just wipe it dry then re-apply lube and maybe wash your bike a little bit less unless its winter.
But if you degrease the chainset (am assuming you include the chain in this) and then apply lube without having washed off the degreaser, aren't you going to cause problems for the new lube?Did mine today.
1. Spray the chainset with degreaser, then go off and clean the wheels.
2. Come back wipe the chain thoroughly with a rag and spray with lube
3. Remove rear wheel, use rag to floss between the cogs
4. Scrub cassette with degreaser, scrape out gunk with a flat head screwdriver, then hot soapy water. Then spray with lube.
It's winter, so wipe down the chain every day and add a small amount of wet lube as appropriate.
