Cassette Removal Hell ! Help
midlife
Blocks don't usually have such small cogs near the tool, easy to check by looking at the shape of the hub
andrew_s
Gloucester
Shimano cassette and freewheel tools look very similar, and with 7 sprockets and a 13/14T small cog it could be a freewheel.
It's easy to tell - put the tool in the splines and spin the sprockets backwards. If the remover turns with the sprockets, it's a cassette, if it stays still with the wheel, it's a freewheel.
The best way to remove a freewheel is to clamp the remover in a solid bench vice, and turn the wheel rim.
HumpTdumpty
HumpTdumpty
HumpTdumpty
Uk
HumpTdumpty
HumpTdumpty
HumpTdumpty
Uk
Here you go re without the tool
figbat
Slippery scientist
That’s a freewheel. You remove it by simply unscrewing it from the wheel. No chain whip needed. Put the tool in then use an appropriate spanner to undo it in the conventional rotation. Or, as others have suggested above, place the tool in a vice, place the freewheel onto the tool and turn the wheel in a lefty-loosey direction.
Ignore me
ChrisEyles
Devon
Agreed, that's a cassette lock ring, so you'll need the chain whip.
Have you tried using the QR to hold the removal tool in place? I've honestly find this very helpful in getting stubborn lock rings off, and once chipped the edge of a free hub applying excessive force causing the removal tool to slip out. Give it a go and get a longer lever on your removal tool.
Another tip - if you're applying opposing forces through a pair of levers, you can generate much more force if you have the two levers (in this case, chain whip and spanner) positioned close to one another (eg at 3 and 4 o' clock), and press them in towards one another. Don't know the reason why, but this allows significantly more (biomechanical?) leverage to be applied.
Apologies if I'm teaching you to suck eggs here!
Sharky
Kent
Thanks, back to thinking it is a cassette.
As others have said, put the qr skewer back in to keep the tool in place. Is your chain whip completely broken now? You might be able to block/jam the cassette from the other side using a screwdriver through the holes in the largest sprocket. And a large spanner or adjustable and a bit of force.
Good luck
