Yellow Saddle
- Loch side.
You are correct. Exceptions are where the manufacturer specifies a wet torque with grease. For the rest, it goes on dry.My understanding is that you _never_ put grease on a thread you are going to torque up to.
Surely no one tightens the ring that much with the sort of tool described above. It must somehow tighten with use.
This ring does not tighten with use because the cassette movement is arrested by the splines. It is the Tarzan syndrome at play here. You'll find it a car tyre shops as well.
