gbb
- Peterborough
Not quite a car, but my latest toy to play with, had to hand crank as no starter motor
Scary
Mid 1970s, we had a brickies mate did a lot of damage to his arm starting a cement mixer, starting arm didnt disengage....
Scary
You could have an issue with the pump/clutch on the aircon ? We leave our a/c on on all our cars, even when cold outside.
@Tom B, does it happen when the air con is on recirculate? Might help you diagnose if it’s happening when pulling hot in and cooling it or just when recirculating cold air?
If you can see the compressor pulley it's worth checking to see if the clutch disengages when you turn the ac off, like any other clutch they wear but can normally be adjusted using shims.
How would I know from the pully?
I can see the pully, but there is no free end at the back of the compressor as such so I can't see if it disengaged.
With the car idling, hot, and the noise apparent it very gently hunts. Put the AC on and the hunting stops.
It also seems to deactivate the stop start too. But i'm new to that so not 100% sure thats the case.
I was going from knowledge on my V70, where you actually see the pulley and clutch engage and disengage from above/below. Maybe not the case on all cars..(it is 25 years old)
NSF outer CV boot has just started to fail, enough to spread some grease around the rim. 36mm socket purchased, no danger of that nut coming undone on a 2ft bar. I have a big impact wrench coming that I hope will work, if 950NM won't do it then I'll take it to the garage!Blowtorch 😁The V70R is back on the driveNSF outer CV boot has just started to fail, enough to spread some grease around the rim. 36mm socket purchased, no danger of that nut coming undone on a 2ft bar. I have a big impact wrench coming that I hope will work, if 950NM won't do it then I'll take it to the garage!
Yesterday, preparing my DILs 2006 Chevrolet Kalos for MOT today.
Replace one brake light
Tighten door strap mount.
Check fluids etc, top up as neccessary.
Oil badly wants changing...a bit of a worry because that will likely effect emissions.
Windscreen wipers might just pass.
One headlight buffed up, was very milky, now acceptable.
Will probably get an advisory for a small tack in the tyre. Been there for ages, im not taking it out.
Its a low mileage car but owned by someone from new who didnt look after it...and neither does my DIL tbh, its not in very good condition really.
3.30 will tell....
