Drago
- Suburban Poshshire
I sneak round Accy's after dark and drain my oil on his front path. Much easier than using a catch pan.
Some cars are a pain to do oil changes. Our easiest was a Yaris. Filter at the front so very accessible. Literal 5 minute change.
Not entirely my experience. Our Prius was lovely to look at but south of 100k was getting quite lacy underneath to the point it was becoming problematic.Indeed. Toyotas are not only well made and durable, they’re very well thought out for maintenance.
Think my battery needs replacing, I occasionally get a 'charging system malfunction' message on the display.
Battery is 5 years old and message only appears on start up then clears almost immediately.
Reasonable to assume it drops just below a voltage threshold on startup. Alternator.must be ok or the fault would be permanent.
EFB technology, £120 for a decent one, considerably dearer for an AGM one.
My brain is still sitting 40 years ago when you could buy a battery for £30![]()
I usually use one of those cheap roasting/tinfoil things as a oil catch...as for stubborn oil filters a screwdriver and hammer usually does the job if I can't get a grip.As in hammer screwdriver into filter and twist 😁
There's always room for a hammer..my most versatile tool 😁Yes I used to see them do that in garages . One chap did it then discovered that it had a bolt at the bottom !![]()
There wasn't much room in my Jag to use a hammer .
Does a small Punto motor need AGM? When researching my new battery I discovered only the big bore pugs with StopStart used AGM, while the 1.6 and below range used EFB, much to my wallets relief.£178; for a semi-decent AGM battery for my Sons 13 plate Punto with Stop-Start.
I was stuck in the £30-£40 pricing too - until it came to actually paying for it 🤣
I was just thinking of the cars which I have had and which ones weren't bad for doing oil and filter changes on . The old Mini wasn't bad once you removed the front grille as it made access to the filter easier. Our Vauxhall Corsa B model 1.2 wasn't bad in having the oil filter placed at the top.
Our Kia Venga 1.6 has to have a small under tray removed but the difficulty is filling it back up as the engine slopes back and the filler cap on the rocker box is halfway under the bulkhead! The number of times I poured oil all over the engine !![]()
