DaveReading
Don't suffer fools gladly (must try harder!)
- Reading, obvs
I was very happy to accidentally find an old French wrench on Craigslist several years ago.
I mis-read that at the first attempt ...
Anything I buy for cycling I need to know I will use it often, since my technical bike knowledge is nonexistent I don't think I will get much use out of bike tools, so I am hesitant to purchase many.
C'mon now, £3.99 from Wiggle!Anything I buy for cycling I need to know I will use it often, since my technical bike knowledge is nonexistent I don't think I will get much use out of bike tools, so I am hesitant to purchase many.
That cost isn't always measured in money either.Bikes aren't complicated, and if you plan on cycling the rest of your life, it's best having them. Just get them when you need them.
A set of hex keys is essential as most bolts need checking occasionally, and I never trust an 'off the peg' bike, or other mechanics. I've only ever tusted one person to build me a bike, and that was for CTW from a local shop and I knew the owner.
Things work loose, and it can be expensive if you don't know how, and potentially very costly if you ignore noises.
I do that sometimes. Particularly steep hills, pedestrianised areas. But not always.
What is £3.99? There has been so many tools recommended I don't know which age the essential ones. I'm getting confused.C'mon now, £3.99 from Wiggle!
It was recommended you buy one when you first asked about Shoes/cleats/pedals early on, I assume you bought on-line as all the shops are closed?
Should have ordered one then really, people answer all your questions thoughtfully and with good intent, I have to say you're very lucky this forum is full of the type of people it is.![]()
What this entire thread of 6 pages is about, a spanner to remove your pedals.What is £3.99? There has been so many tools recommended I don't know which age the essential ones. I'm getting confused.
I think you are exactly right here. Some people have a real interest in and ability to carry out any conceivable maintenance issue. This is great as everything I've read indicates it gives them real satisfaction.Anything I buy for cycling I need to know I will use it often, since my technical bike knowledge is nonexistent I don't think I will get much use out of bike tools, so I am hesitant to purchase many.
Most pedals are never, ever removed, and stay with bikes till 'the end' because they are more robust than the bike.
A pedal spanner is low on the list of tools needed.
I have no interest in performing cycle maintenance and have everything done by my LBS. Any investment I made in tools would be wasted.
If you establish a good relationship with an LBS many small jobs like this will be done for free or minimal charge. This is why for some cyclists, me for example, it is so very important to always purchase from the LBS rather than the apparently cheaper option of online purchases. Literally anything I need doing my LBS will fix in minutes when it could take me hours. This is because they know I will always buy from them first and never online. Yes many things appear cheaper but it's impossible to purchase service.
The money you save on tools can be invested in quality clothing etc. which you will use daily.
Perhaps I could refer you back to my opening paragraph in which I acknowledge for some there is great pride and pleasure in performing all their own maintenance. This is great it's part of their joy in cycling.I disagree completely. I've removed a number of pedals. I've acquired used bikes with one busted pedal or a mismatched pair. I've had a pedal bearing fail and the pedal all go wobbly. Sometimes I might swap a crankset for some reason. So there's been occasions where I've needed to remove one or both pedals, to replace a faulty one, or to swap out an odd pair for a matching pair on one of my better bikes. It's not a job I do every week, but it's not once in a blue moon either.
I find the attitude of those who seem to take pride in being mechanically inept very strange, TBH. You may consider tool money "wasted", but think about this:-
If I have a mechanical issue I can almost always deal with it at home, at a time of my choosing, on any day of the week. and the time doesn't cost me a penny.
On the other hand, you have to make a special journey to the LBS every time you want something done, and either pay for the work or pay higher prices for your parts & cosumables in order to get quick jobs done "free". Most of the time, I will probably have a problem fixed in less time than it takes you to get to the LBS, and I'm not constrained by the opening hours of the shop or how busy the mechanic is.
The tools vs clothing is an odd argument. I can ride a bike in any sort of clothing, and you can have all the fancy cycling garb in the world, but if your bike doesn't work and you haven't got the means to fix it you aren't going anywhere.
