Anonymous1502
Thank you I will walk my bike (since I have one pedal and ask at the local bike shop.This and ask them to fit the new ones while you’re there as not in possession of a pedal spanner![]()
To be fair the weather is pretty minging in London for cycling (well and walking)Surely you have two pedals, the one you removed and the one still fitted, so why not ride it?
There's tools you can improvise and other tools that you cant. I've never needed anything more than a 2 lb hammer and a block of wood to insert bearing races like headsets. Unless you are a clumsy oaf they are a five minute job. Jobs that involve very tight or seized fasteners need brute force, and you can't successfully apply brute force unless your tool fits properly and won't slip off and chew up the thing you are trying to remove. Pedal spanners are worth buying, headset presses are not.
My LBS has never charged me for a pedal change...but then they get a fair amount of business from me (going back to flats has meant a lot of pedal changesMight be cheaper to order a pedal spanner OP, the bike shop will charge you about the same.
)One flat and one clipless. Like wearing two odd shoes, e.g. walking boot on one foot, slipper on the other.![]()
Did you follow the link upthread, £160 for a couple of washers & a screwed rod?I've never begrudged the cost of tools.
Use them once and they've usually paid for themselves.
