Yellow Saddle
- Loch side.
The only luck involved is the designer's luck that most people don't know what they're looking at.take the nds crank off, and just check if the circlips have been installed in the shell.
I think you have just very unlucky for something like that to happen.
How rough does the actual bearing feel?
Press fit bb are very simple... but they do not tolerate water ingress at all well. Water getting in from the downtube for example and simply left to do its worst over months.
How rough? So rough that if you remove the chain and spin the cranks, you think someone started a small lawnmower.
Yes, press-fit is simple to install but problematic, as discussed above. Further, removing a press-fit destroys the plastic cup unless you are very lucky. Unlike a screw-which can be removed routinely for a clean and re-grease.
