Yellow Saddle
- Loch side.
Sounds good. I'll do that next time I need a new BB. Forgive my ignorance, but would buying the converter and new cranks also necessitate a new chainset?
That's my intention. I went like-for-like this time around for financial reasons (i.e prioritising new helmet & wheels!) but next time I am looking to change it. Again, would this require a new chainset too though?
Could you recommend a good square taper? I was looking at one of these but I think it has outboard bearings - best avoided?
http://www.hopetech.com/product/threaded/
That would explain the phenomenon of the improved BB life second time around, I guess.
Yes, a converter will require a new crankset. If you go for square taper, you will require a square taper crank and if you go for 24mm Hollowtech crank, you'll go for a BB such as the Hope one you have linked.
Best Square Taper is Shimano UN-54. They don't come any better than that. Square taper and outboard bearings are the exact opposite of each other. Square taper has inboard bearings, Hollowtech has outboard bearings. The latter is an OK option.
