Pardon me aycejay, thought you were
 ill get back to you in a second.
Rob as always, words roll off your tongue like water off a ducks back
 good schooling
I make no mistake when I talk about strength,  not talking about power, power is the rate of work after all correct? And strength isn't so yes you are correct but I'm not confusing the two.
I feel cadence is another good fad the magazines etc have decided to press on, along with economy, nutrition etc however, they focus too much on these small fads when the major benefaire is still power and endurance. People get tired of being told how to make power and they still have to sell issues.
I talk of muscular connectivity strength, the kind that either allows you either to push a larger gear or not. If you can grind a 53-13 but cant grind the 53-12 you dont have the strength to. which is one principle of power in my eyes. You TT at 70rpm, as that's where the power is, let me assume you're a naturally very strong guy. If you weren't you couldn't turn that gear as the cross over point from cadence to strength to make power has far since past at that rpm.
Higher strength does improve time to exhaustion as well as a great deal more, and Ive personally always found this to be the case, both running and cycling. With more strength, load is reduced in relation to your maximal strength. Its a case of having the legs or not having the legs.
I would recommend everyone who can, if they periodize, do a coarse of weights, not flaffing around in the gym, i mean focused squat, lunge, dead lift and press.
You come away feeling very very  light going up hill!
how ever, because the body runs the way it does, you find muscular fatigue is delayed and rather than having a huge spike in power output as strength goes up (which can be done through your specific training) as that is what makes you faster.
Yes plumtree, intensity above AT can be sustained for a period. It depends what level above. Intensity at Vo2 max.Now thats 5 minutes of pain then you die.
I am so glad everyone over whelmingly  is chiming Cycling is an endurance sport!! now lets drop these HIT workouts early on and build the fitness first
Good effort
