uclown2002
- Harrogate
Nice one. Just checked my Garmin and it had defaulted to 'Do not include zeros'Entire ride. You can turn off including zeros in cadence averaging in garmins thus a true average.
Now if cycling was a strength sportIts a coping method chuchilo
Ulrich grinds-muscle strength runs out#screwed
Armstrong spins-aerobic capacity has limits, when reached- drop a gear and have all the muscle strength Ulrich has dumped ready to play with
I would be screwed then lolNow if cycling was a strength sport
I take mine from strava segments as I ride in a lot of traffic . RP is a pretty clear run for 7 miles so I can compare from that at this stage anyway .When calculating a cadence average is this over the whole ride or just when you are actually pedalling? Guess it has to the latter or averages could get thrown out quite a lot if freewheeling times come into the calculation.
That doesn't make sense Jason. Are you saying that when someone reaches their "aerobic capacity" they can continue on "muscle strength"?Its a coping method chuchilo
I couldn't when I tried it . I just went home .That doesn't make sense Jason. Are you saying that when someone reaches their "aerobic capacity" they can continue on "muscle strength"?
Do you not ride? When you breach your aerobic threshold you turn anaerobic, and you're in a better position if you still have all your muscular strength, which will break down but it is better to keep it as long as you can. No strength is the premier reason why people walk up hills pushing a bike/ just go home cuch lol
That is just completely wrong Jason. The words should be a clue 'aerobic' means with air (oxygen) and 'anaerobic' means without air. An endurance sport like cycling obviously relies heavily on aerobic capacity and this is the capacity that is built up during base miles. A body can only operate for a short time without oxygen but the anaerobic threshold can be increased too with appropriate training methods, when you reach your threshold you will know as the lactic acid will tell you, once you have reached this point no amount of preexisting strength will help at all.
