david k
Hi
- North West
but none of this takes into account cadence, what your describing is someone who gets fitter goes faster, nobody is disputing that as ar as i can see.Option A - If you attack the hill at a higher effort than you can maintain, you will hit (and exceed) your LT and/or VO2 max very quickly. It is not an easy thing to recover from, espcially if the road is still going up.
Option B - If you ride up the hill below your threshold (ie at a gear and an effort you can maintain) then you will be able to maintain a consistent effort all the way up.
Of course option B is quicker, because you have not hit the wall half way up. However, if you train yourself to perform option A, it will obviously be quicker and you will end up being able to ride option A in the same way as you are currently able to ride option B. It's called 'improvng your aerobic fitness'...
The question is in reference to higher cadence lower gear same speed = climb as quick for longer as per quotes i;ve given.
You claim overwhelming evidence contrary to my opinion, all I see is explanation that training will make you fitter, thats not evidence
