Cable ties are just the best. Fact.
Matty
Nr Edinburgh
Had to replace a rear mudguard on the commuter. It was most probably busted by bike shop, but was 2 years old and terribly rattly. Can't be doing with rattles at all.
Tried to remove, but fixings (after 2 winters) pretty stuck fast, especially the stoopid fiddly one near bottom bracket. WD40 - no use, couldn't find pliers, went to buy pliers, still couldn't get off, ended up hacksawing the bolt - without the hacksaw handle (ouch!!). Finally got it off and attached the new one with ......... cable tie. Simple, tighter, doesn't rattle and will be a doddle to remove. Now looking to cable tie everything on the bike. Nuts and bolts suck.
biggs682
Northamptonshire
i have 2 bikes in use with cable ties securing mudguards to the frames , works fine
M
Matty
Nr Edinburgh
I just remembered, it's cable ties holding on my turbo hose on the broom broom. That was an RAC man roadside bodge, several years ago.
LosingFocus
Lost it, got it again.
Yep one of the best things you can carry with you. They have a multitude of uses many of which are only apparent when a given situation arises :smile:
Good makeshift handcuffs.
Parrot of Doom
They're good for snow traction (disc brakes obviously) by wrapping 20 of them around the rim and tyre.
Also, if ever you get a snapped spoke at the threaded end, bend it 180 round and cable tie the resulting hook to the tyre.
david1701
Bude, Cornwall
copper slip man :ohmy:
but yeah cable ties rule :biggrin:
