Good afternoon,
Which has been debunked. To save my from typing something up again, here is what I said on another thread on here.
tl;dr if you only had a limited amount of time and not infinite, you will ALWAYS burn more calories and / or fat at higher intensities in absolute terms.
Just to be clear I agree with what you have said above.
The Fat Burning Zone, doesn't exist but there is a valid marketing/course viability reason for using the term.
Imagine a Local Gym that offers 2 classes, one at 80% max heart rate for 1/2 an hour and one at 50% max heart rate for a whole hour.
Assuming that both classes burn the same number of calories (tweak the heart rate % to make this true) then the people taking the classes could very easily have different weight loss experiences.
The high heart rate class will by using more glycogen, if the class member weighs themselves every day this will result in more weight gains and losses as it is used and replaced.
This may be demotivating for someone who doesn't really understand the role of glycogen and doesn't really want to learn, they just want to lose weight.
Added to this the casual weight loser "knows" that carbs are "bad" and might avoid them, so are in a greater danger of complete glycogen depletion by accident, an unwitting day 3/4/5 of an Atkins diet/bonk. This may put them off exercise completely.
The low heart rate class is much less likely to see weight changes from glycogen depletion because of their proportionally higher use of fat.
The low heart rate, Fat Burning, class may also be more likely to continue to attend because they enjoy the lower intensity and the phrase gives them a good feeling about their exercise programme.
Okay it is not the most efficient plan but that's their choice, after all there is evidence starting to come to light than long rides, Iron Man triathlons etc may cause significant heart scarring that may be a problem in later life. I'm not going to stop longer rides,..... or take up Iron Man.
I do agree that over a reasonable period of time the weight loss from either routine would be the same, unless the see-sawing in weight from glycogen loss/replacement causes the high heart rate class member to stop going.
Bye
Ian
