derrick
- On the edge of London
I don't think those spring are designed to stretch that way, so it might be too hard. I seem to recall putting one on a gate completely wrong once and the gate tried to eat you before you were through it. Luckily I realized my mistake. In front and parallel would probably be better.Decided to drop the idea of an Ackerman steering system... going for traditional rope steer but (humour me on this one) what would happen if I put 'Gate close' springs on, attached to both side of the front steering board as in (badly drawn) diagram below.... would it help the steering re-centre itself or would it make make steering too hard for a 10 year old? opinions please........
I have googled it and no one seems to have tried it... does this make me an innovator like Henry Ford and Preston Tucker.......
The spring is not meant to stretch but to fold/compress, so fit them so they don't stretch, like belowNot sure what you mean..... ( a diagram as badly drawn as mine is ok........)
You'll add a hazard that wasn't there. What happens if the spring on either side were to give or the mounts come off?
With no feet on the front, it'll pull to one side.
Move the front axle back, allowing the feet to help steer. A lot less trouble than springs.
More or less. Also help with the steering though. Should the rope break, the legs take over on their own.Wanted to keep his feet away from moving parts but I assume you mean take away the foot rest (fitted as shown in picture) and use the axle board as the foot rest?
