As I said, the 5% (provided the wheel is true) is not something you have control over. It is a direct function of the rim's uniformity and I've explained why they are not uniform. If the rim requires 30%, there's nothing the wheelbuilder can do to narrow the gap other than make the wheel not run true. When you achieve 5% you should not tap yourself on the shoulder for good building, you should tap yourself on the shoulder for finding a uniform rim by pure chance.
My last attempt to see if we understand each other
Say that you have a rim that needs one spoke needing considerable more tension to get the wheel true. You say I have no control because that is the nature of the rim I'm using, right? Well, I'd spread the extra tension between two or even 3 spokes, also, I can reduce tension on opposite spoke(s)
but most likely I'd use a combination of the two if the imperfection is large enough. I think you are saying, just leave the spoke with considerable more tension alone.
A wheel that requires glue to prevent the nipples from unscrewing doesn't have enough spoke tension. Thread ramp friction at tension of 1000N or so is sufficient to require a large force to turn the nipples. Glue is not required.
The method that works for you, works for you. However, it is not the method that ensures that you don't have loose spokes, it is rim quality. You are still new in the game, wait until someone buys some Chinese carbon rims on the Internet and asks you to build wheels from them. You'll quickly discover that the highest spoke tension is more than the nipples can handle without rounding off whilst the lowest is barely enough to get a tone from plucking the spoke. No matter what method you use, the end result is uneven spoke tension.
OK, NDS spokes on a rear wheel will have less than 1000N so they should have glue, right? I have never used glue on a spoke and I hope I never have to.
The end result may be uneven spoke tension but uniform, not one highly tensioned followed by one severally under tensioned.
EDIT: I wasn't sure why you were bringing up spokes tensioning to the point the nipple rounds up..... then it cane to me
IIRC you are from the school of Jobst Brandt that finds the max tension a wheel can take by tensioning the spokes to the point the rims deforms and then turns the tension back a bit. For all the respect I have for JB, I never thought that method was one I'd want to apply myself so I don't see how I could find myself in that situation. Also, when there's not enough tension for plucking to work then I use a tension meter.
With very thin flat spokes, my tension meter cannot read the deviation at low tension but I'm not too concerned, at higher tension the meter does read the deflection which is what I need to know. I have a device to calibrate my tension meter that I use with some spokes to find out what number corresponds on the meter to a known amount of kgf. There are some tension meters now that can read deviation at low tension.
I'm well aware of your opinion on tension meters so no need to be rude about it
There ain't no shades of a perfect wheel and a perfect wheel has no even spoke tension, no matter what semantics you employ.
I wasn't using any semantics, sorry
I agree, there's no perfectly even tension on a good wheel, nobody is saying there is. For that matter, there's no perfect wheel either but good enough wheels.
I am not sure what rims you build with but all quality rims have an extra lump of metal at the weld. You have to remove the blindfold when looking for it, because it is inside the rim, not on the outside. There is no other way of welding and machining a joint on thin-wall aluminium than with the help of this internal sleeve. Perhaps you should look inside for the lump, not on the outside. It is in the form of a thick sleeve, about 50mm long, inserted inside the two ends of the rim and peened before welded and machined. Every single rim has one. You can also see its effect on the rim if you put a finished wheel in a stand and let it spin a bit and come to rest. It will always come to rest with the lump at the bottom and the valve hole at the top. I'll dig for some old rims and take a photo of this sleeve.
It seems I misunderstood what you meant about the location of the extra lump of metal, it immediately came to mind some joints I've seen on old rims and poor quality wheels, hence the confusion. I do agree that rims aren't perfect.
I've seen rim's joints.
