BS6102 regulations for brakes? Tackling a non-compliant bike
Sheffield_Tiger
Does anyone have a copy of BS6102 (the section relevant to brakes)? I can't find my old Cytech folder with it in, but it might have changed since anyway. I'd be interested in the exact wording
Reason is that I've spent the evening assembling some new (to us) bike stock.
I can't mention the brand as I can't be seen to be publicly criticising the brand we stock, but it is a low end, around the Townsend/Falcon level and the MTB and hybrid bikes seem passable, as expected for the price. In fact, apart from the fact that one flat bar road model arrived with a bent gear hanger, I was tempted for a budget winter hack myself.
The issue is the road bikes. The calipers are actually pretty good, for single-pivots. Low drop, chunky alloy, they do a job. But the Brake LEVERS....
I worry about these bikes if someone less qualified assembles them and sells them/rides it. Set the front brake up, pinch bolt was a bit naff but it held on a second tightening. That was worry one, bit too much torque needed - simple answer change the pinch bolt.
BUT - when I gave the brake levers an "emergency pull" - *POP* - the lever hit the bar, the brake disengaged - the nipple housing had totally detached from the actual lever.
Set up the rear brake and did the same test, applying the brakes hard, and the same happened. I expect flex etc in cheaper brakes but this - this in an emergency would leave the rider with NO brakes at all.
I've seen these (or similar) levers on long drop steel sidepulls and they are probably OK, the flex probably takes away the resistance - in a way I think that the calipers are too good for the levers.
I'm sure these can't be up to standard, even the loose standard of 6102. Second question is where should I go about my concerns? Don't want to hinder supply of stock and cause trouble between companies but don't want to ignore this either, in my view they should all be recalled.
On the positive side, at least I have a say in our stock so I can veto bikes with these levers
RebornBumbler
Barnstaple
Just don't buy any until the problem's fixed.
The supplier should be able to offer a solution. We had a similar problem and the supplier was persuaded to supply us with newfront brakes levers and forks - plus the labour cost of fitting it all.
raleighnut
^^^^^^+1 its down to the supplier/importer to rectify you need to inform them as the compensation claims that could arise from a fault like this are immense.
Trading Standards would be where I start as it could just be a dodgy batch of levers.
Sheffield_Tiger
Sheffield_Tiger
Oh I'll be informing them. But I get the feeling that they are a BSO brand cutting costs and it will be a "we've had no other complaints". So those levers will be going somewhere else...I don't think they are "low quality" I think they are dangerous and need removing from the market.
For our part, I'll not be stocking any more of their road models. The lever isn't a "dodgy batch" - the fault is designed in (I have history of Cytech and MechEng)
The one we have is getting a set of Dia Compe levers and sold with those as "last in stock" so it will be perfectly safe to ride
