Tread Patterns
Tread for off-road use
Treads can help improve off-road traction in two ways:
- The knobs of the tread can hook onto projections of hard, irregular surfaces, reducing the tendency to slip.
- On soft, squishy surfaces, the knobs poke into the surface, digging in for improved grip.
- In the late '80s, there was a revolution in tread design, started by the Specialized Ground Control. This tire, and many later MTB tires, had tall knobs at the side of the tread, with extra bracing to keep the knobs from being bent away from the centerline of the tire. These knobs greatly improved performance in sand and mud, because as a section of the tire rolls into contact with the ground, it flattens out. This flattening out causes the outer knobs to bend inward, so that they grab a loose surface like a pair of pliers.
Tread for on-road use
Bicycle tires for on-road use have no need of any sort of tread features; in fact, the best road tires are perfectly smooth, with no tread at all!
Unfortunately, most people assume that a smooth tire will be slippery, so this type of tire is difficult to sell to unsophisticated cyclists. Most tire makers cater to this by putting a very fine pattern on their tires, mainly for cosmetic and marketing reasons. If you examine a section of asphalt or concrete, you'll see that the texture of the road itself is much "knobbier" than the tread features of a good-quality road tire. Since the tire is flexible, even a slick tire deforms as it comes into contact with the pavement, acquiring the shape of the pavement texture, only while in contact with the road.
People ask, "But don't slick tires get slippery on wet roads, or worse yet, wet metal features such as expansion joints, paint stripes, or railroad tracks?" The answer is, yes, they do. So do tires with tread. All tires are slippery in these conditions. Tread features make no improvement in this.
