T4tomo
Unless you aren't doing any hills at all the 2spd is quite limited (but a good option for a flat town commute) which is why Berlinonaut is recommending it I guess.
3 spd is most robust for minimal maintenence, As the 2spd and 6spd rely on the rear derailleur, which as mentioned further up thread, can be temperamental if not kept clean.
I Have had several years on 3 spd standard and then several on 3spd - 12%, I favour the latter. Better to run out of gears at the top end than the bottom. You won't use 1st in London on either set up though!
