Spoked Wheels
- Bournemouth
4 of my bikes have got 36 spoke 4 cross lacing on the rear wheel and there is another 'spare' wheel the same, best pattern for strength/longevity.
Do you have any proof?
It shouldn`t happen, you must have a duff wheel to start with, it does happenBloody expensive way of life this if wheels just randomly give up the ghost! I wasn't off roading or anything!!
Only the advice of John at Bob Warner Cycles who builds my non-standard wheels (a few of my bikes have 'off the peg' wheels) and he has been building wheels since before I was born. (I'm in my mid 50s) John was given the shop when Bob retired and he now runs it as a 'one man band' although John himself is now well past retirement age.Do you have any proof?
4 cross is a tandem spoking pattern and is usually used on 40 or 48 spoke wheels but will translate to a 36 and he reckons it is better for carrying heavy loads or pulling a trailer because it allows more flex and avoids the 'overload' tension snapping a spoke.
In my case it was for the somewhat prosaic reason that the spoke size required for three-cross lacing (254mm) was not available from my chosen supplier. Going with four-cross allowed me to use 264mm spokes instead. I don't worry my little head about factors such as the relative radial stiffness or strength of different lacing patterns....why would I build a standard 36 spoke wheel in a 4 x pattern when a 3 x pattern would give slightly more radial stiffness and offer no advantage in strength and life to fatigue?
That's a perfectly valid reason, and like you say don't worry about the other stuff. BTW, there is no increase or decrease of strength or stiffness in 3 or 4 crossings. It is all in the mind of some builders who come up with these claims without any backup.In my case it was for the somewhat prosaic reason that the spoke size required for three-cross lacing (254mm) was not available from my chosen supplier. Going with four-cross allowed me to use 264mm spokes instead. I don't worry my little head about factors such as the relative radial stiffness or strength.
