So I'm a huge noob in the world of cycling, and following everybodys recommendation, I practiced taking off the wheel and replacing the inner tube so it should make road repairs quicker.
That all went well, however, my brakes are permanently stuck on. I did unclip the brakes from the little bracket they sit on to allow me to get the wheel off, but when I went to clip them back on they seemed a lot stiffer to clip together and as a result my brakes are stuck on. I don't believe I touched any of the brake cables, I did slightly loosen one caliper and reposition it as it was lop sided...but both calipers are touching the wheel suggesting the cable is too tight somewhere.
And problem number 2...there's also a rubbing sound coming from the cassette, but I can't see anything rubbing. I've obviously messed up somewhere.
I don't know what to check or do next so will appreciate any expert input!
Thanks!
Thanks!
