Profpointy
Am I missing something here, surely if you ride on the left hand side of the road and want to turn right, you will be braking with your left-hand and signalling with your right. So you will actually be using your back brake? Hence why the brakes are st-up depending on which side of the road you ride on.
Yes you have understood the situation, but not grasped it's a problem. Aforementioned Black Boy Hill is reasonably steep, so if you try and brake with back brake only, you will lock up back wheel, skid, then likely fall off - or if you don't brake quite as hard as that, you won't actually slow down, never mind stop! You need front brake to stop, and hence can't signal. On the flat, not such an issue.
Basically back brakes or for very gentle slowing or as a last resort, and not really for proper braking
