MickeyBlueEyes
Eat, Sleep, Ride, Repeat.
- Derbyshire
SwissStop Black on the best bike and Clarkes on the hack. Best bit of advice from Globalti, keep your rims and blocks cleaned and the difference is well felt.
I'm going to order a set of the Raleigh
Probably not quite such an issue in a road bike DaveS, but I managed to wear a Mavic 517 rim on my MTB down to a point where the sidewall split away from the rest of the rim in the space of just two years. Mind you, that did include two years pretty hard winter series XC events, and countless MTB orienteering weekends. I always used to run quite soft brake pads on the front during the winter, so that combined with gritty, slimy mud used to make for a very abrasive grinding paste on the rim.Interesting comment re rim wear. I just had to part with my beloved Mavic Open Pros because one of the rims had corroded right thru by one of the spokes. Braking surfaces were fine though. I should point out here that they are 20 years old and in pretty much daily use LOL. Can't complain at that can I?
Are concerns over rim wear from calliper brakes unfounded?
I have hydraulic discs on my current MTB DaveS and there is no comparison between the stopping power of them and rim brakes, however it was always possible to pull up pretty quickly with XTR V-brakes and the appropriate pads.Wow. Real use case for discs then.
I actually believe there would be no problem in changing a disc brake wheel in a race situation DaveS. OK, you probably need a little bit of practice to slot the disc straight in to the gap between the two pads, but experience on my MTB tells me it's no big deal. Must admit though, I can't really get excited about discs on road bikes, as I think they just look a bit industrial! I couldn't wait to get them on an MTB because of the obvious benefits in stopping power in less than ideal conditions, but that immense hike in power is not essential on a road bike.Disc brakes also make carbon rims more relevant. Perhaps costs will come down. The current crop of so called direct mount rim brakes are said to rival the performance of V brakes but I have not tried them. I can't see how wheels can be changed in moments though a la Tour with disc brakes, and if racers won't use them, their progress will be slowed. With respect to brake pads, the best results I have had have come from the Clarke's Elite pads. They can be had for around a tenner a pair, are supplied in a Shimano compatible holder, and come with a spare set of pads. Better in the dry than anything else I have tried, and about as good as the best in the wet. Pad is multi \coloured\compound.
