Brake bleeding-was the wrong fluid used?
Try bleeding again, but go to Epic Brake Solutions and download their detailed instructions. You push fluid in from the caliper first. They have some good instructions and there is slightly different process for both makes, but it also recommends a few things to ensure air is out from the lever at the end of the bleed.
R
ryckee
I will try loading the levers. I don't see any signs of fluid or leaks anywhere. I also may try placing the levers a little closer to the handlebar and rebleed them. But i will try loading them and check the seals first. Thanks for the tip!
