Trouble is, it's outside of the derailleur frame that is rubbing. I can stop the rubbing if I pull the cable tighter by hand when in low gear. It is like the whole FD would fit better if it was laterally spaced another 2mm away from the frame and more in line with the chainset.there are trim positions with the shifters. This means you can do a half click with the left shifter which moves the derailleur inwards a small amount to stop rubbing
Nothing wrong with 5800.....
I am not able to disagee, it's the first groupset I have experienced. I do believe that I have been blessed/spoilt by my late brother.It's a very very good groupset
It's a bike Jim, but not as we know it5800 on a boardman sport - that will be a first!!
Well I only have very limited experience. Compared to the Allez which was a bit too small it's just as fast, just as agile and due to the longer wheelbase a bit more stable when turning, especially at slow speed in tight turns.Waiting for an update,how's it ride 😁?
Just changed the +4/-4 100mm stem for one advertised as +26/-8 90mm stem.
Went for a short ride and was surprised at the improvement in responsiveness in the steering.
Do you have the 2 stems on identical cycles?suprised you could tell the difference in handling , i run 110 on one and 80 on another and i can tell nowt
I got one of those frames too the large one eventually doing something similar though not painting it
