TK421
Casual Extremist
- Not at my post
Got a profile shot
I can see why you suggested black for the forks @Jameshow . Definitely a possibility but maybe gloss black to match the seat post.
Remember N+1 says you can never have too many bikesYou almost tempt me as if I don't have enough bikes!!
Dunno, haven't finished building it yet. It's the first cycle I've ever tried to build and the first cycle I've ever owned. Still learning how to rideHow does this one ride?
Got a profile shot
It's a W.I.P. and I'm on a steep learning curve, but it's quite fun. I have found a local bike fitter (NOT Halfords!) to straighten out the kinks.very nice , bars are a bit of angle though![]()
Will get them adjusted.Bars should be level with the hoods and stem tbh.
I don't actually have an aluminium road bike!!
Had a blue Ribble which was dull.
The frame is listed as a Boardman 51.5cm small frame for riders who are between 162cm and 177cm tall. I'm 166cm tall with a 29" inside leg so it should (please note the should) fit. The 51.5cm is C-T on the seat tube and from what I've been reading bike geometry is based upon the effective top tube and seat tube to determine the reach and stack and thus the height and inside leg measurements of the rider. I get the feeling that the effective seat tube is more like 53 or 54cm than 51.5cm. I also didn't realise that not all bicycle manufacturers quote the effective height to size their products until after I purchased the frame and started to have doubts. I did think it odd that Boardman suggests a 45cm frame for female riders the same height as me. I looked at several sizing charts before I bought the frame and depending on where I looked I found that I should be riding anything from a 50cm to 54cm frame bicycle so I went for something in the middle. I started thinking that this frame was definitely too big when I set the saddle so that I'm on the balls of my feet when I'm sitting on the saddle.If that's the right saddle height, the frame is way too big for you. Bars need to be rotated by at least 30 degrees.
