jwarwick
- South London
ould be looking at this bike for commuting, general riding year round (so a spare pair of tyres - Gatorskins? - will be needed) and maybe some 4 or 5 day bike tours with camping stuff. Would I need to look into lower gearing, especially for touring? I'm aware that I'm a bit stuck for easy gear swaps, as a larger cassette will mean a mountain bike derailleur too, and a triple chainset will mean a new derailleur AND levers
Yep, I think I'm looking at getting the Spyres. Interesting about the gearing, I think you're right about it being fine for general riding, still not sure about it for touring, weight would most likely be sub 10 kilos, but it still could be a problem... The trouble is I can't really justify a second touring bike at the moment, will look into perhaps swapping chainsets for a triple, but a move to 50/39/30 doesn't really move the lower boundary much, so it'd have to be a touring or mountain bike triple, which means new derailleur(s) and levers...![]()
I've got Spyres(the SLC version as that was the only ones I could get at the time without a long wait) too on my Planet X XLS and they have been good so far,only downside is they squeal a bit in the wet but that's the only down side really.
They do, but you can get older Equilibriums with a triple, if you're willing to go second-hand -The Rove and Equilibrium both have the same gearing as the Boardman
The Boardman is certainly comfy enough. I think I was envisaging you tackling 70-100 mile days. At 40 miles, taking it steady, you should have no problems. Just make sure you get some tyres on there that roll well. Depending on what size you're looking at Schwalbe Duranos, Conti 4Seasons and Marathon Deluxe are worth considering. I suspect a change of wheels if future funds allow will also make a significant difference.three day or so trips - looking at (hopefully) sub 10kg of kit meaning just rear panniers and 40 or so miles a day
I'm not a fan of the BB5s at all so unless you try the Comp and the Lyras are terrible, I wouldn't consider upgrading on that basis. Apex is fine - takes 15mins or so to get used to, then you're away. Easy to adjust and changes are smooth enough, though not as smooth as my Tiagra, and I prefer the feel of Shimano levers.I've heard mixed things about the standard Lyra brakes, but I don't think the extra £200 or so upgrade to the BB5s on the Team is much better (plus SRAM Apex looks difficult to master!)
There's no reason why you couldn't do one at a time. I'd probably save up and do both together just for the convenience of doing the whole job in one go.is it silly to upgrade one brake before the other, or better both together?
Sorry, not sure about this and I don't think Halfords stock any bikes with Spyres to compare. I think @tincaman has done this upgrade so he might be able to help.I think they both use the same rotor, can anyone confirm this?
I believe the Comp did genuinely sell at £699 with few or no reductions for a year or more after coming out, and the Team similarly at £899. You'd have to be a mug to end up paying full price now though as they seem to be in one offer or another as often as not. If you don't pick it up at £150 off now, I doubt you'll have trouble getting it at that or cheaper at some point in the next few months.I was just interested in the boardman because it's at £150 off, although I suspect it's never sold at full price
Judging by the comments on here Shimano and TRP hydraulics are streets ahead of mech disc set-ups. Again, it comes down to how much you can afford and what kind of riding you do. I'd like hydraulics but I can't justify the outlay as I live somewhere very flat so I'd only really see the benefit a few times a year when on longer rides and cycling holidays.If you are looking to upgrade might be worth looking at TRP hyrds or even proper hydraulics at a later date
On a budget presumably around £500? What's he going to use for wheels, dustbin lids?!Get a Kinesis disc brake frame and build it how you want?
I didn't see him mention a budget, just that he was buying a £500 bike and then changing all the partsOn a budget presumably around £500? What's he going to use for wheels, dustbin lids?!
