Slick
I've bleed my shimano 105 brakes as per the usual suspects videos on YouTube, I even repeated the process to ensure there was no stubborn air pockets, I then made the mistake of reading the instructions that came with the kit and I started following them before totally confusing myself so I started again from scratch but there was zero air 3rd time out and I just ended up swapping oil.
My brakes now work but there is still a lot of travel in the lever and I thought the bleeding would have solved that so I suppose my question is, can I adjust the lever to reduce the travel to the bite point or has something else went wrong with the bleeding operations?
