winjim
I don't know, I need to check its value with the OP.Depends ... does it fit me and are you selling it for a fiver?![]()
The performance gains of aero design components are most effective if you ride very quickly. For elite riders, even marginal gains are important and a few of them stacked together can make the difference between gold and silver.That is a load of rubbish.
No-one expects to go "twice as fast" but if you are denying the performance gains associated with higher end wheels (or other kit and components), you are a long way wide of the mark.
For slower riders the effects are exceedingly marginal .
The most cost effective component upgrade for any rider are tyres, then maybe a new stem/bars to get your body position more aero.
Upgrading from light to ultralight (eg 105 to Ultegra) is a marginal gain for athletic riders. Many smaller, non-athletic riders are using bikes that are excessively heavy, by several kg. Upgrading to light makes a difference to acceleration, so is a safety measure.
There are good unbranded carbon frames made in China but also sub-standard look-a-likes. The problem is knowing which one you have.[/QUOTE][QUOTE="Arrowfoot, post: 3608208, member: 18391" ordering carbon frames and components from China and they seem to do the job. And there are copies of well known bikes.
Vendors now realise that buyers are now more discerning and checking and getting advice on online forums, clubs and friends. So they now moving away from usual stock wheels. Its a good sign.But what if your bike already has Askiums already on it?
Blimey, don't think I'd volunteer for that one!Maybe someone should organise a double-blind test to find out whether a million pound wheel-set (for example) can really make you go twice as fast.
Why would upgrade a new Aksium, either get the vendor to upgrade to the spec that you looking for or use it until it times to replace to an upgrade. Nearly all the vendors ar prepared to upgrade components.
So you're saying that wheels don't get any better than Askiums?
No. For £150, the Aksium or an equivalent is a big jump from the stock wheels that come with entry level road bikes. It makes the most performance wise, not groupset upgrade, or any other component.
Alternatively spend the £150 on comprehension remedial course.
