Darius_Jedburgh
Thanks. I've taken the plunge and ordered one.
Next is to work out a quick way of moving from bike to bike. I suspect a bodge may be involved.
Can't you get around this by using loop recording?
Thanks. Mine will also go under the bars. As I use more than one bike I'll be looking at a quick switch set up. I "think" I can fix it so that I can use the quarter turn lock on the underside of the latest Garmin mounts.My set up.
It saves hard metal projections if I were to go head first over the bar and in my opinion, makes the camera less obvious.
If I was to regularly switch bikes, I'd try to change the clamp with the allen head bolts to a cam lock or possibly butterfly fasteners.
The one downside I found to this set up is the USB charging port is less visible. I know where it is, but getting the connector the right way round was a bit fiddly. That was solved by putting a piece of brightly coloured tape on the "up" side of the charging connector.
Charging port is now stated to be USB-C so no problems about right way up.
All will be revealed in a couple of days when it arrives.
Yes, that's exactly what I'm planning. Postage is indeed high -£10 even if you buy a system. Think I can construct a mount from my spares box, if not they are freely available on eBay for only a few £££ post free.Like you I was concerned about how to mount the light, but I've kind of solved this for my use case more generally, I have a Garmin out front mount which has the Varia under mount (same 1/4 turn mechanism). I've got several front lights I can swap in or out this way - mostly Lezyne though, but in principle it can work with any light which can use a go-pro fitting.
I ordered a go-pro mount for the fly-12 which I then use a Garmin Varia mount to connect to the underside of the computer mount. I can get any of my lights off the bike in a couple of seconds and remount them just as quickly. In addition the mount is really solid - and doesn't shake, nor have I had a light come off during a spill. I used the lanyard to fix the camera to the mount a bit more securely as at the time I didn't trust the Cycliq mount.
Doesn't everything have to be USB-C nowadays?
Heard good thinks about this. I found the bracket on the Fly12CE woeful - The only downside to the too light/camera is the lumens don't seem quite as high as the cyliq
https://www.swinnertoncycles.co.uk/tooo-cycling-camera-light-front-camera-light-combo-dvf100-p126945/s369390?utm_source=google&utm_medium=cpc&utm_term=tooo-cycling-camera-light-front-camera-light-combo-dvf100-tooofc01&utm_campaign=product+listing+ads&cid=GBP&glCurrency=GBP&glCountry=GB&gad_source=1&gclid=Cj0KCQjwsaqzBhDdARIsAK2gqndrpnL_MHv2ISJ82UY02wdIuqD5gLxioH1y1Trp1hjJPyc_fbFGcC0aArPyEALw_wcB
To be honest, I only run the Cycliq in a flash mode (I use organic flash) as the main beam output (nominally 400 lumen) doesn't put much usable light on the road. Both my big Lezyne light and the Fenix BC30 put out much more usable light at half that as the optics spread it much better on the road. Pretty sure if I was doing a night ride I'd opt for a different light.
Just out of interest do you camera users use them only as evidence gathering or do you ever use any of the footage/stills for general recreational photography/ upload and share type use
