I have had the ChilliTech Camera, not terribly impressed, gave it away. I now have AKASO EK7000. Quite happy with the video quality, but, the battery life (3 hours) would not suit your requirements. Battery is removable, and, the camera comes with two batteries, so, if swapping batteries is acceptable, you could achieve 4 hours. One point to note, if/when you remove battery to swap/recharge, you have to rest date/time. Not difficult, but, a little bit annoying. Sample footage here.
Video quality looks good. Ordered one of these yesterday from Amazon and delivered today. You do get a lot of goodies with it, i must admit. Just charging the batteries up as I write.
One question, how stable is the bike handlebar mount, as you seem to need to use a number of components for this.
the mounts off eBay, look like this:https://www.ebay.co.uk/itm/Aluminum...p2349624.m46890.l6249&mkrid=710-127635-2958-0
Got a feeling the Fly 12 CE is only available from cycliq themselves directly. I even think it may have been discontinued.I'm in the market for Cycliq Fly12 front camera, as nothing else seems to tick enough of my requirement boxes. But there is no stock anywhere in the UK, (or anywhere for that matter) which is really annoying. I've also mailed Cycliq direct and they have no idea either, which is really helpful!
I had the first generation rear Fly6 camere/light which served me well. Then I updated to the Fly6CE, which was even better and well worth the upgrade from the original. But I see now that they have released V3 of the Fly6, which if what I'm reading is correct, it has a lower capacity battery and half the lumens of either the last two versions? Okay, its lighter and smaller, but at what cost, less bright and less battery life
Thanks for the tip and I will be using the waterproof case. I’ve ordered a more discrete mount than the one that came with the kit, which will allow me to take it off without tools as I don’t want to keep it on the bike all the time.
I have had the ChilliTech Camera, not terribly impressed, gave it away. I now have AKASO EK7000 (approx £50, on Amazon etc). Quite happy with the video quality, but, the battery life (3 hours) would not suit your requirements. Battery is removable, and, the camera comes with two batteries, so, if swapping batteries is acceptable, you could achieve 4 hours. One point to note, if/when you remove battery to swap/recharge, you have to rest date/time. Not difficult, but, a little bit annoying. Sample footage here.
A work around for the date and time reset, is to have a little power bank with you, and plug it in the camera before you take out the battery, put new battery in then unplug the power bank the date and time stays correct this way. It might sound a bit fiddly but it works for me.
Great idea. I never thought of that! Thank you for sharing, I will try that.
So far on my list is the cycliq fly12, anything out there better than these?
Update to this old thread in case it helps anyone.
I've been looking for years - and tried several including the most-advertised products without success - before I recently found this (relatively) inexpensive rear-facing light + camera a few months ago .....
<https://www.tooocycling.store/> (also available from several other sellers)
Reviewed here: <https://www.t3.com/reviews/tooo-cycling-dvr80-review>
My experience= Footage is clear in daylight and at dusk - I haven't tried at night - even though there is no video stabilization. Construction seems robust, IPX5 water resistant, easy to mount, 8+ hr battery life, 2 year warranty. >1000 min recording with a 64Gb microSD card, automatically overwrites earliest segments when card is full.
One glitch is that there is no dedicated app, so you have to edit and upload a .txt file to change the date/time, or reset video frame rate and other options. The instructions are fine and I had no problem doing it, but some may find this control mode bothersome.
