Do you know the changes with the CE model? Been trying to see what they were but struggling to find the details.Cycliq Fly 12 user here. To date a great bit of kit. I get the feeling they spoiled it with CE version.
You might be able to pick up a second hand one. There are online guides about changing the batteries, if a duff battery is the only issue.
Note you also need specific memory cards for them to record properly.
IIRC a shorter battery life was one of the changes. If you have a look at dcrainmaker.com he does in depth reviews of cycling kit and the Fly12CE and its rear facing little brother have come under his scrutiny.Do you know the changes with the CE model? Been trying to see what they were but struggling to find the details.
As for the drift XL I see there’s been a few issues and the image doesn’t look as clear as the cycliq.
also looking at garmin they quote 3hours which would be the minimum I’d be looking at
fwiw - I recently put this unit on my wish-listghost XL
Have took a punt on the ghost drift XL. Will post up my feedback once I have it up and running
Iv ordered the handlebar mount to attach it thereGood luck and I hope you don't have anything too terrible to report !
Will you put it on the bars or the helmet? I tend to use helmet for commuting and bars for leisure.
I like the concept of Cycliq very much and know others who run then fine, but I have read so many reports of problems with themI'm in the market for Cycliq Fly12 front camera, as nothing else seems to tick enough of my requirement boxes. But there is no stock anywhere in the UK, (or anywhere for that matter) which is really annoying. I've also mailed Cycliq direct and they have no idea either, which is really helpful!
I had the first generation rear Fly6 camere/light which served me well. Then I updated to the Fly6CE, which was even better and well worth the upgrade from the original. But I see now that they have released V3 of the Fly6, which if what I'm reading is correct, it has a lower capacity battery and half the lumens of either the last two versions? Okay, its lighter and smaller, but at what cost, less bright and less battery life![]()
I like the concept of Cycliq very much and know others who run then fine, but I have read so many reports of problems with them![]()
From the other posts iv seen and looked at I’m quite impressed with the ghost XL so that’s the number 1 contender i think now beside the cycliq fly12 although the newer CE doesn’t seem to get as good reviews.
I’m only after a front, I don’t want anything to cheap £100-£250 is where I’m looking.
Original fly 12 was good. Once you accepted it's quirks.I like the concept of Cycliq very much and know others who run then fine, but I have read so many reports of problems with them![]()
There is another option - on Amazon I think - that like cycliq combines a light and a camera. Was just over £100 - horrible oblong shaped thing though. Reviews seemed decent enough
