You can ask him.
FWIW I suspect* the chainset is a knock-off of a Sugino Messenger. If so 103mm JIS would likely deliver a 45mm chainline. What you might want to know though is that typical fixie/ss chainline is usually 42mm if the dropout distance is 120mm, but you will find it hard/impossible to get a JIS bb shorter than 103mm. In fact Shimano don't make any shorter than 107mm.
* why possibly a knock-off you might ask? I think so because I saw new ones being sold just over a year ago, and they also look just like these, and I have never seen real Sugino with that emblem or being sold so cheap (around £20 brand new iirc). Also the seller didn't have a clue what bb the chainset needs when I asked, and has since "left" ebay...
Surely chain line is the distance from the centre of the hub to the centre of the sprocket. I can't see how dropout width can affect this.What you might want to know though is that typical fixie/ss chainline is usually 42mm if the dropout distance is 120mm, but you will find it hard/impossible to get a JIS bb shorter than 103mm.
I was thinking from the point of view of having the same wheel. For example,a wheel that is 120mm OLN has a sprocket screwed on giving a chainline of 42mm. ie the distance from the centre of the hub to the centre of the sprocket is 42mm. But I want to use it on a bike with 130mm OLN. So I add a 5mm spacer to each side, bringing the OLN up to 130mm. The distance from the centre of the hub to the centre line of the sprocket is still 42mm.Chainline is the line the chain takes from front to rear sprockets. Drop out width will be a factor, because it will affect hub choice, which will affect chain line.
Iv found an old bb from a bike I stripped ages ago ( I cant even remember which bike, ).it's an old type but the bearings are caged , its 107 mm so I'm gona try it and see if it lines up , if not at least it gives me a starting point.
Can u use Vaseline in place of grease? Iv no grease but Iv got a jar of Vaseline in the bathroom
No idea which it is , how du tell? JIS ,,, ISO ,,,, eh??? I just thought a square taper is the standard
So what Iv got would work but might throw the chain line out
Cheers , but let's get to the important stuff , is Vaseline a go lol. ( where's fnarr
