I recently went for a bike fitting session with Paul Hewitt. This was partly in preparation for buying a new bike from him, but also because I wanted to see if I could adjust my riding position to eliminate the lower back pain I often get when riding.
As others with a similar problem have reported, Paul suggested I ride in a more stretched out position – basically by moving my seat back and fitting a longer stem. He also strongly advised me to try these changes out on my existing bike before investing in a new bike, as a more stretched position might not work for me.
I have now modified my existing bike as he suggested and went for the first long ride on it last weekend. Unfortunately the results were not good and I experienced worse lower back pain than I have done for a considerable period of time
Even with my old setup it seemed to be very hit and miss when I would get back pain. One some long rides I would experience virtually no problems, while just a few days later I could get chronic pain on a short ride.
So my question is, should I persevere with the setup Paul has recommended to see if things improve after a few more rides? Or should I start making incremental adjustments to his recommended setup to see if this helps – for example by reverting to a shorter stem?
Finally not sure if this is relevant, but I found that when I was in the more stretched out position I was having to tilt my head further back in order to see forward, and this felt as if was making my lower back pain worse.
It might be worth trying one just for the sake of research and if it sorts out your back pain then why not?
