gazza19
- halifax west yorkshire
sorry just looked again it says 37-622
Was that complete with a wheel, as it won't fit on your existing one. There are several ways of measuring tyres and the least confusing and most accurate is to use the ISO/ETRTO system. This means 37-622 or 38-680.yea ive tried a 27x1 and a quarter 38-630
No. He's tried 27 x 1 1/4 .Get 622 not 630 (27 inch). And get 25mm tyres, so 25-622.Try and get 27x1" - those are huge tyres for a racer.
This is exactly what I'd do.Looking at the pictures, it looks like the rear gear hanger is one of those which is just screwed to the frame. It also looks as if the position of the axle could go back another half inch.
Inspect what you have. If you can remove the gear hanger, you might find it could be moved back a bit. If the retaining screw is restricting this, you could remove it and just rely on the axle nuts to keep every thing in place.
Keeping in touch with ISO/ERTRO that's the same as 28-622.700 x 28c is the biggest you can fit on one of these and it's quite tight at that.
