Sloth
Try removing the peak of the helmet if you can, see if it helps![]()
Will do
Fine in principle. But does make the assumption that humans are built equal.Cycling is not supposed to be hard work at all. Mile for mile, it's easier than walking. If you're really knckering youself, you're doing it wrong.
All I get after riding for hours is a bit of general tiredness, nothing is burning or giving me actual pain.
My bike fittings across different bikes aren't all identical either, and therefore can't all be perfect, and in reality probably none of them are absolutely optimal. They are just close enough to get away with.
It's meant to be hard, you just get faster.Eh.... Does not compute.![]()
The handlebars look to 31.8mm because they're tapered. Easily measured just next to stem
