Are my shorts past it or is it a bike fit issue -updated info
Punkawallah
Ditch the ‘incontinence pad’ and just wear a pair of running shorts? You then no longer have the ‘pad shift’ problem. Works for me, anyway.
cyberknight
cyberknight
If this is correct I imagine it's very easily checked. The pad is either securely sewn in place or it's not. A ten second look will determine this.
If the pad is properly secured in place then it has to be the shorts which are moving and the pad with them. This will be because of 3-4 years incorrect washing.
I can pull the shoots away from the body easily under the pad.tried a different pair of shorts today and although not perfect I
At least I wasn't sitting on the pad stitching.i did fiddle with the saddle so I will check I didn't muck that up
