Marin Maniac
spandex said:If you have a look at the ring you will be able to see two wear points if you think of the ring being a square it will be the left and right hand sides. That is where the power is going into the chain not the top or bottom. So if you turn it 90 degrees you are in some ways giving the chain a new set of teeth to play with.
When you say wear points, are you referring to the chain rotating on the big ring or where you shift up and the chain joins the big ring? I get the jist of what your saying, however it doesn't make that much sense bearing in mind the ring is constantly rotating, so in my fuzzy logic the wear on the ring will be equal around the ring?
