Anyone want a hanger tool😂
Kbrook
Profpointy
What is it supposed to be for?
I can't even guess, either from the picture or the term "hanger tool"
Loch side.
It looks like a RD hanger straightener that doubles up as a brake lever synch tool. It helps you get both levers at equal height. Quite a bit of lateral thinking in there. Now those fake bike fitters can obsess about one more thing.
  • Like
Reactions: C R
Big John
It's a tool for not only straightening the hanger but seeing if it's out of line. If you're having trouble indexing the gears this'll tell you if the hanger might be causing the issue. They're easy enough to use if you know how and you can make your own with a bit of help from YT.
Bristolian
Bristol, UK
Several YT channels have featured this recently - even Calvin at Park Tool. You can use the hanger tool to check that your brifters as aligned in both height, angle and distance potentially alleviating discomfort when riding.
  • Like
Reactions: C R
C R
Worcester
So does this one have a means to attach it to the top of the steerer? Mine only has de M10 bolt.
