Brad123
Have been wandering about that, at what point do I just give up. I normal try hang in. I will look up the tableThis is to be expected, the 1st few you are fresh.
Andrew Coggan and Hunter Allen propose a system for determining when to abandon an inteveral session (or how to decide how many reps to do, in a more positive sense) and the baseline they suggest you use is the power in the 3rd interval (which they deem as the repeatable interval). Then they propose you should stop when your power drops by a certain percentage of the power of this repeatable 3rd interval (the percentage varies depending on the duration and intensity of the interval, you would have to look up the table to get the correct values). In the case of a VO2 max interval (duration 3-5 mins) I think they propose a 8-10% drop in power from the 3rd interval is acceptable, any more and you are no longer training at the required intensity and should stop, you have done the optimal number of repeats.
Thanks
