slowmotion
Quite dreadful
- lost somewhere
The front mech parted company with my bike frame last September or thereabouts in the darkness between Oxford and London. @Fab Foodie did the surgery, handed me the part, and I have been on ten gears ever since, usually 34 on the front, but I can flip it to 50 if I don't mind a greasy finger.
The coiled spring pin, which acted as the hinge pivot for the FD frame clamp, had sheared. I pushed the remains of the broken pin out of the aluminium housings and found that a 2.5mm diameter drill was a snug replacement for the sheared pin. See piccie.
£1.49 (postage included) buys a 50mm length of 2.5mm diameter 316 marine grade stainless steel rod which should act as a reasonable replacement for the broken pivot.
Do you have any suggestions for neatly expanding each end of the new pin to stop it going walkabout?
Almost any violence (file gouges, plier scars, punch dings etc) would work, but what's an elegant way?
Thank you.
Thank you.
